Is there any problems going to a type II TC style power streering pumps.
JDNobodi
3/4 ton status
Santa Maria, CA
I'm looking to shave some weight. Yes I know that just a pump change is not going to do it. There is going to be a lot a things that I'm going to be doing shave some weight off my pig. The steering system is just a small pebble chipped off the boulder. I'm looking at a lot of pebbles.
Anyway, here a pump I'm talking about.
http://www.speedwaymotors.com/High-Flow-Aluminum-Power-Steerng-Pump-for-T-Bird-and-GM,10488.html
So if any of you had any problem this kind of swap, what size tires are you running and have you installed hydro assist?
They are good pumps, you may try and get pressure and flow numbers from them.
You're going to need a lot of those pebbles to make a difference :eek1:
i'm gonna run similar.. psc's high end pump.. mainly cuz i'm doing a remote ressy... i figure a killer pump is in order with boost and assist...
