Is there somewhere I can get factory accessories for an 80 blazer?
The1980BEAST
Ft.Worth Tx
I need to get a tailgate cable, two tail gate latch points (recievers? the little metal part that the latch, latches to) and an interior door handle..
The local autozone and o'rielys dont have them and cant get them ordered.
Check with the dealer too...if it's still available, most all the aftermarket suppliers (LMC truck and the like) simply sell you the GM part to you at dealer price, plus their cut. I need some tailgate cables to, I can probably pull those part numbers if you like. Scratch that. 14021315/14021316 LH and RH cable springs respectively are unavailable from GMPD, 6274850 is the cable, available at $17.99 from gmpartsdirect.com, plus some ridiculous shipping I'm sure. You need the springs though...mine both broke, you'd THINK they would still sell them. Someone might make an improved cable, it's certainly needed. Stainless would be nice.
I believe I have some used ones in my garage that you can have. I live in Keller. I'll check tonight. Send me a PM.
Napa also carries the cables. The latch points you are probably going to have to get through the dealer, or from LMC or Classic Parts. Unless someone here has a set they aren't using anymore.
I have one cable from Napa, and need to buy the other.
