is there speacial oil for limited slip rear ends?
yes and no
they make an additive that you put in your diff to preserve the limited slip. napa has it.
Go to the GM dealer. It is called Limited Slip additive, and about the best there is....
/forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif
Replace the rear cover seal. Clean the surfaces very good. Make sure the cover is flat. Use some silicone, and a gasket....
Really /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
10b gaskets should be all over the place....A bead of silicone that has had time to 'set' will work too....
<font color="red"> how in the heck can you not find a 10b gasket? do u go to napa or autozone? or sum local garage? i mean, almost anyone should have a gasket for those, cus they're so common, but, silicone always works well, just make sure its made for it, dun go to home depot and grap a tube. lol. </font>
Yeah just run a nice bead of form-a-gasket and it shouldnt leak a bit, thats what I did to my daily driver and have had no probs.
Dont waste time and money on a gasket. Just use silicone, put it on the cover , put the cover on, add friction modifier and oil and its done.
