is this a good deal?
Flamin' Fast
Registered Member
Bountiful, UT
i want somemthing that i can drive around and maybe do a little towing
http://www.ksl.com/index.php?sid=&nid=443&tab=list/view&ad=760426
i emailed the owner about the a/c, cruise, oil leak, and a few other things. this was his reply
"The turbo system is a Banks. As for the oil leak I think it is coming from some oil cooling lines that go to the radiator. The cruise hasn't worked from the day I got it. I believe there is a module under the dash that needs to be replaced. I really don't know for sure. I use the truck very little so it just hasn't been an issue for me. I suspect the ac just needs charging"
does this seem like a good deal? what else do i need to ask and what should i look for if i go take a look at it
not too bad.... I'd be reeeeeeaaaaalllly curious about that oil leak though.
I'd look it over real well then buy it if I didn't see anything real bad.
im going to go look at it. i know of the main things to look for, but ive never had a diesel. anything i should listen for or anything like that
