340 Horsepower 435 Ft. Lbs Torque
HT 383E High Performance replacment for 1996-1999 Light Trucks 350R engines
An emissions-legal small block that brings on the torque for your '96-'99 GM truck/SUV!
The HT383E crate engine from GM Performance parts is an exciting new extension of our “High Torque” line that is especially designed for '96-'99 full-sized GM pickup trucks and SUVs that is a direct replacement for your high-mileage 5.7 liter stock engine.
The HT383E offers you the same brute strength of our HT383: forged steel crank, 4-bolt main cast iron block, and a camshaft designed for towing and hard work. With 383 cubic inches, you also get a broad torque band that peaks at 435 lb,-ft, at 4000 rpm with 340 horsepower at 4500 rpm.
Our GM Performance Parts engineers designed the HT383E so that installation is as easy as possible. Simply, swap your new HT383E in place of your existing 5.7 liter engine using your stock intake manifold, wiring harness, and fuel injection system. The stock computer adapts to the new HT383E, and you suddenly have stump-pulling, big-inch small block at your disposal.
Engine Kit Includes:
14" automatic flexplate, balancer, water pump, spark plugs, spark plug wires, oil filter, oil filter adapter gaskets, intake gaskets, exhaust gaskets, complete vortec distributor, A/C Delco spark plug wire set.
Specifications:
Horespower-340@ 4500 RPM
Torque- 435@ 4000 RPM
Maximum Reccomended RPM 5000
Compression Ratio- 9.1:1
Internal Components:
Block- Part # 10105123 Cast iron, 4 Bolt main, With 1 piece Rear main Seal
Crankshaft- Part # 12489436 Forged 4340 Steel, Externally Balanced.
Connecting Rods- Part # 12497624 5.7" Powdered metal.( special design for 383)
Pistons- Part # 12499103 Hypereutectic, Dished top , With offset pins.
Camshaft-Part # 14097395 Billet Steel Hydraulic Roller Camshaft.
Intake Lift- .431" Intake Duration @ .050" 196
Exhaust lift- .451" Exhaust Duration @ .050" 206
Lobe Centerline-109
Rocker Arms- part # 10089648 1.5:1 ratio Stamped Steel, Self Aligning.
Cylinder heads-Part # 12558060 Cast Iron,64cc Combustion Chamber,170cc Intake Runner,Raised Runner Intake Port Design, with "Vortec" Specific Bolt Pattern. Standard Exhaust Port Shape And Bolt Pattern Layout. Straight Plug Design With Centerbolt Only Valve Cover Configuration.
Water pump- Cast iron, New GM 1996-2000 Vortec engine water pump
