Is this a good way to ID a 14 bolt open or gov-lock differential?
divorced
3/4 ton status
It seems that about once a week someone posts a pic of a 14 bolt carrier wanting to know if it's an open differential or a Gov-bomb. Sometimes it is hard to tell from the pic what it is because of the angle, and difficult to decide if it has 3 pins or 4 pins. I was looking at some pictures I have saved of 14 bolt carriers and noticed something: Each one appears to have 12 ring gear bolts. In the pic of the Gov-bomb it appears to have 4 ring gear bolts between a set of pins, but on the open differential there are only 3 bolts between each set of pins. By using this method it would seem easy to ID a differential just by counting the number of ring gear bolts between a set of pins.
Would this method of identification work?
Example: It is clear in this pic that there are 3 ring gear bolts between a set of pins, indicating an open carrier. (unless of course a Detroit has been installed)
yes i like your metod of id for 14 ff axle carriers.
that one looks like a locker is in it also. no gears in the slots.:D
Yep, I think so too. I "borrowed" it from another post... :blush:
And your blocks will ship tomorrow, we have a trip planned to the big city :D
For the sake of having it all in one place...
On a 14 bolt Gov Lock carrier, the carrier itself will be smooth and cone shaped on the ring gear side with 3 sets of 2 round cuts outs (revealing clutch plate locating tabs). These round cut outs are circled in red.
(pic from AkFabShop.com)
I dont mean to be ignorant but to me, the difference is clear. The gov loc carrier is smooth on the outside, an open carrier is not. A gov loc you can see the clutches, the open you see the side gears (or spring if a lockers in it). Gov loc is a 3 pin, open is 4. They dont look the same at all.
Dont mind the yellow circles.
Yep, your right. I was thinking it may be easier for the guys who pop the cover off their first 14 bolt and don't really know what either should like like.
I like those pictures better than trying to explain to someone. Always better to see the inside of the carrier so they can see the difference between 3 and 4 pin spiders. :cool1:
OK, I'm gonna throw a wrench into the works here. My carrier looks just like this one BUT it has 4 pin holes instead of 3. No, I did not miscount, I even had someone else count them just to be sure. No one so far has been able to explain this to me.
Pics?
If you're counting the pins with the diff still in the housing be sure to mark one with paint or something so you don't accidentally miscount.
One was already marked with yellow paint, there are four. I'm not gonna pull it apart just to take pics, but next time I have it apart I will get some pics.
