broncoman6524
I recently killed a $300 roller cam in 1500 miles....
Fuel pump lobe went flat, I did not have anybolts hitting the pushrod, they were all aftermarket "bolt kit" bolts.
I did however have a standard pushrod, the following link says that the metal used in roller camshafts, can be hardened by standard pushrods and I need this pushrod with the roller tip.
http://www.summitracing.com/parts/CCA-4609/
