Is this going to cause problems?
johnnychimpo
Nash, TN
I put the '92 2wd brake hoses on my K20 (4" frt springs) but putting the banjo bolt block in between the ears on the caliper did'nt give me as much slack as I had hoped for. . Will they loosen up during susp cycle/turning wheels if mounted to the caliper like the attached pics? It looks like the ears on the caliper stop any movement from this end of the hose. The brake lines I bought were left & right side for a '92 c1500 is this correct or is one side better to use than the other, I searched when I bought them but couldn't remember that far back.
I wouldn't worry about it. I have had to run them that way for years on my K5 & never had any problems. I did make sure that the bango block was up against the ear on the caliper though.
