elks
So looking at my 14 bolt I discovered a few things that surprised me.
The spindles are welded on? It this normal? It looks factory, but the only full float axles I have are fronts. If the are welded on do they have an inner spindle bearing? If so how to clean it? Pack it etc? I have the housing sand blasted and unfortunately there is sand every where.
Also where the axles tubes go into the housing one has only a 1.8 of machined smooth surface showing out side the housing, the other almost a 1/2" Are the axle tube identical or is one supposed to be longer? This 14 bolt is from a van.
