Is this normal for a Water Pump???
Ryan B.
3/4 ton status
CA
This happened on my big block in my Camaro...
At about 6,200 rpms. I thought i blew the engine, when all i was hearing was my water pump gernading in half, destroying the water pump, flex fan, radiator, fan shroud, water pump pulleys, and crank pulleys. /forums/images/icons/mad.gif /forums/images/icons/frown.gif
And it smashed the inside of the hood pretty good, even chipping the paint on the outside of the hood in two places. /forums/images/icons/mad.gif
This is an edelbrock water pump that is supposed to be a contingency item with the NHRA according to summit racing.
Has anyone seen this happen to a water pump before?
I can see a casting line on the inside of the water pump... following where the water pump cracked in half... I'm thinking this could be an imperfection in the casting which weakened it.
Do you think Edelbrock will replace this pump or pay for the cost of it?
My friends tell me they should be paying for more than just that water pump!
Anyone dealt with Edelbrock? They seem like a reputable enough company they might warranty the pump and pay for a new one or something. ? /forums/images/icons/mad.gif /forums/images/icons/frown.gif /forums/images/icons/confused.gif /forums/images/icons/shocked.gif
Time to order my CSI electric water pump, Be cool radiator, electric fans, billet pulleys.... etc...
ouch??? never seen that, it must have been under a lot of strain, but i don't think it should have snapped like that. was it a new part?? if so send it back. good luck /forums/images/icons/confused.gif
Check your warranty. Depends on what it says. Write Edelbrock, send the pictures in and see what they say.
I had a similar experience on the strip with a Edelbrock water pump but mine didn't just split in half mine grenaded into about 5 pieces, I did the same that your doing we put on a CSI electric pump. I didn't even think to call edelbrock, heck mine did happen at a wee bit higher of an rpm 6800to be exact. Jesse
only had the main shaft bearing go out on my stock one.it started smoking so i shut it off before it actually fell all the way apart.that was a nasty break.of course i dont really run much over 4000 rpm either
<font color="green"> You should stop using a 5 foot cheater bar to stretch the belts when you're setting the tension /forums/images/icons/laugh.gif. An inch of play is fine... Never seen that one before, I'd definately call Edelbrock on it.</font color>
I wouldn't tell them you were using a spacer.They may not warrenty it if you say you used a spacer.
Oh......by the way.
Ryan asked me to make a small correction to his original post. The engine speed was acutally 16,200 RPM instead of the 6200 RPM he originally stated.
Do you think this makes a difference?
/forums/images/icons/grin.gif ROTFLMAO /forums/images/icons/grin.gif
/forums/images/icons/shocked.gif HOLY COW ! look at the way that thing chewed into the radiator! /forums/images/icons/shocked.gif Damn dude... thats impressive. At least you have pics of it /forums/images/icons/smile.gif
Tori-
Yeah, I'm pretty proud of destroying the radiator in both of my vehicles within about a month of each other. /forums/images/icons/smile.gif /forums/images/icons/grin.gif /forums/images/icons/shocked.gif /forums/images/icons/crazy.gif /forums/images/icons/frown.gif /forums/images/icons/smile.gif /forums/images/icons/laugh.gif /forums/images/icons/tongue.gif /forums/images/icons/grin.gif
At least this radiator i won't be changing out front of your house in pismo beach. /forums/images/icons/smile.gif
