Is this right? 56" spring question.
85 Jimmy
Sheepdog
Gulfcoast
I want to replace my rear 52" 2" lift springs in my truck with 56" springs. Right now I have 6" lift springs in the front, 2" lift springs and a shackle flip in the rear. My goal is to flip the 56" spring and run a zero rate to move the axle back 1.5"-2". That will give me about 5" of lift in the rear, right? So to get the extra inch, I need to replace the 4" shackles, at least I think I have 4" shackles, with cross tied 6" shackles, right?
If all that sounds about right, what do I need to look under for 56" springs? 1 tons, suburbans, newer like 87 and up trucks?
Using 56's backwards will move the axle back 4", the zero rate can only move it back forward 1-1/2". So it'll push the axle back at least 2-1/2".
Most 56's came in 3/4 and 1 tons, though they were occasionally used in 1/2T Suburbans. They're usually very stiff out of the box, so people pull leaves to make them softer. If you use them hard like that, they die fast.
gm spring code for 56" eye to eye springs . in the aftermarket world of part #'s
the 22-547 is 2600 lbs per pack .
the 22-547HD is 3500 lbs per pack .
the 22-617 is 4000 lbs per pack .
the 22-617HD is 4650 lbs per pack .
so watch what ya get . you get your hands on the big stuff even removing leafs wont help much .
