Is this the right transmission mount?
75-K5
3/4 ton status
Anderson, Indiana
Can anybody help me with an Energy Suspension part #? Summit's website is being an idiot and showing me mounts that I know are incorrect. I need a mount for a sm465/205 combo out of a '72 K5, being mounted into a '87 K5. It looks like the ENS-3-1106 is what I need but the applications page lists it for being for automatic transmission only. Judging from this pic:
And this pic off Summit's website:
That's what it looks like is on this one, so I'm just not sure.
Any input?
Those mounts will work as long as you are using a crossmemeber from a 1984 on down truck . The 1985 on up "W" type crossmember will not work with the lower drop adapter mount that your 1972 set up has .
Tom
Oops, I already ordered them. I have 2-3 crossmembers laying around so we'll see what develops, thanks!
Quick update: I used the beefy style crossmember that mounts to the upper and lower frame rails both (has extensions off the main piece so actually looks like a big arch). Worked like a charm! I'm not sure what year truck that one was out of since I had so many floating around. I think it might have been the stock '87 one, or maybe it was the one that came with the sm465. :dunno:
Just FYI in case anyone else was wondering.
