ISO Hydro boost set-up
firemedicsafd
Professional Murphy magnet
St Augustine, Florida
i need hydro boost brake system for my K5. i have 1 tons and want to convert it before a finish the brakes on the axles. i need the master cylinder, hydro boost, lines to and from the pump, and anything else that is needed that i forgot. Thank you for your help!
I have everything you need including the pump...it came off a 1 ton chevy...$125.00 plus the ride
fyi brake pedal is different pin location and also van has 2 studs and 2 holes at firewall. hydro boost has 4 studs at fire wall.
both easy to fix / work around .
