DR
So, I have a 2006 Jetta tdi that has an AC issue. The compressor started squealing one day. It appeared to be coming from the clutch. It only made the noise at an idle, and stopped if you shut the AC off. But, it was still blowing perfectly cold while running.
So, I replaced the compressor and the idler pulley, vacuumed the system and started filling it back up. By second can, it was squealing again. The pressure at the time was 220ish high side and 22ish low side. So, I then replaced everything else... condenser, expansion valve, and filter /dryer. Vacuumed, starting filling, exact same problem. The entire system is new... what am I missing?
