cameronsaddress
The brakes on my blazer just don't seem to have enough power. I can slam on the brakes at 20mph and it will take a couple seconds to stop. I would like it to come to a creating halt but no dice so far. I have replaced the following:
Master cylinder
Rear shoes
Front calipers and pads
Rear spring kit
Wheel cylinders
The vacuum to the booster is not leaking.
Should I be able to lock the tires up with enough force? What am I missing?
Master cylinder
Rear shoes
Rear spring kit
Wheel cylinders
I think like everyone else said, just make sure your system is bled properly and you have vacuum hose on the booster. After that, you may try pulling the front calipers and roughing the pads/rotors with a die grinder. Don't remove a lot of material, just scuff it up. My boss used to call it a "non-directional finish" and it helped with squeaks and braking. While the calipers are off make sure your slides are clean. If the calipers are hanging up then only the inside pad is trying to stop you, and that's a real issue and will cut braking distance/power tremendously. If none of these work I'd say the booster is your next move. Keep us updated on what works for you though
