It moves on its own, 1990 S10 Blazer SAS..Update....Done
tlspeed
Registered Member
Arkansaw, WI
This my brothers rig that we have been working on and off for awhile. Its still a work in progress, but it moves and stops on its own.
Specs are
1990 S10 Blazer
4.3 V6, 700r4, np231
Ford HP Dana 44, and welded dana 60 with 4.10s
Custom SAS with Jeep leaves in front,
Custom leaf pack in rear using stock s10 main leaf
38.5 boggers on 15x10 steel wheels
Still needs traction bars, skid plates, front drive shaft, bumpers, hook points, some sheet metal work, paint, and lots of small items that i forgot.
Gawd that things so ugly its badass.
super cool fab work though, out of curiosity, what made you guys run shackles in the front?
Yah its ugly now, but after some sheet metal work and some paint, matching wheels, it will look jsut fine.
Im not sure i follow you on the shackles, the front mount of the front leafs are solid, and the shackles are to the rear like conventional full size chevys. The rear is also set up like a conventional truck too.
i dont know what i was thinking, I see it now apparently I somehow mistook the rear end picture to be the front... Nice build dude!
that rear driveline is awesome! Ive never seen a square tube slip shaft, have you run it before or is it new to this truck?
This shaft is new to this truck, but i have run them on my truck for a couple years now.
Bad pic of drive shaft, but is there
Well we finished up the truck and had it out wheeling 2 times now. Besides some minor tire rubbing, we had to put in a new axle joint and outer shaft, a new tranny mount, and we changed the steering a little bit.
Wish we had wheleing pics but we forgot the camera, so heres a poser pic.
