Its a long shot but...
k5freak44
Texas
Im having trouble finding a 9in grade 5 bolt. Is it possible totake a 8in that i can find and cut it and weld in another inch of grade 5 bolt?
If i did this would it have more strength then a grade 2 bolt?
unless you are a good welder it will be weaker than grade 5 for certain. Whats this for? You should ALWAYS try and use the shortest fastener you can, its just stronger to use say 2 1" long bolts than 1 9" long one.
1in bolts wont reach!
ive gotta go thru my floors thru some 3in body lift blocks, mounts, some bushings and the frame. If i coulda used 1inch this problem wouldent have exhisted!
Thanks tho
You can't find the right size at a good hardware store? If it was me and couldn't find the bolt I would get a piece of all thread, cut it off at the right length, and just tach weld a nut at one end to keep it in place as the head.
sled_dog said:
grade 8 all thread? nut at both ends. Just a thought.
I dont know if this is the same thing Alan is talking about, but my dad bought a bunch of 12'+ lengths of threaded rod (probably not grade 8 though) and whenever we didn't have a bolt at home, he would cut off the rod, and use nuts at either ends.
McMaster.com has them. Type in bolt, then fill in the blanks after that. First select the length you want.
-Chris
LOL I just called it rod because I didn't know what it was. Thread all it in then.
Thanks Alan.
sled_dog said:
yeah thats what I call All Thread, different names for it I'm sure.
look at a farm store
You might try Tractor Supply or a similar farm store,they usually have longer bolts there than most hardware stores carry--I used some long carriage head bolts grade 5,used on plows and disc harrows,only place I could find both grade 5 and that long--the carriage head was a plus too,doesnt make a big lump under the carpet...I saw long enough ones at home depot,but they were grade 2--I have used them before too,with no problems--ANYTHING was better than the pencil thin rotted bolts I took out!..:crazy:
Is there an echo in here?
