Dabba
So, how is everyone? Its been quite a few weeks since i logged in here. Been busy with work and any spare time i had was on the boat which i was using my m1008 to tow it. Well, its getting colder and the transom on my hull is shot so, boats done for the year. Need to find a new hull. And my friend bought an older wrangler so we decided to go wheeling. Well apparently last time i dunked the hubs.. i forgot to repack em
. So we go wheeling today and im wondering why my trucks being such a pig. Get into some deep sand and it becomes fairly obvious 4wd isnt working. I get under the truck and shaft is spinning, so we take the hubs off and one or both are frozen. I wasnt quite sure how they worked (d60, warns), but i saw how when you turn the nob, it pushes in this ring around the axle shaft. On one side, the ring was flush with the rest of the stuff inside the rub, and when you turned the nob it didnt push it, so we got that unstuck and popped it back on. The other side worries me a bit more. The other side seemed to be stuck pushed in, which means its frozen locked right? I'm not sure how im gonna unfreeze it. I piled in wd40 so i can get the hubs to lock and to get home. Im now gonna get some grease and repack em, but im just hoping i can get it unstuck, no wonder my gas mileage has been sucking.
The other question is if i needed new o-rings for the hubs, i would go through warn im guessing right? I think everything else is okay, just super dirty. Do the hubs themselves come apart any more for cleaning purposes, its pretty gritty in there..
. So we go wheeling today and im wondering why my trucks being such a pig. Get into some deep sand and it becomes fairly obvious 4wd isnt working. I get under the truck and shaft is spinning, so we take the hubs off and one or both are frozen. I wasnt quite sure how they worked (d60, warns), but i saw how when you turn the nob, it pushes in this ring around the axle shaft. On one side, the ring was flush with the rest of the stuff inside the rub, and when you turned the nob it didnt push it, so we got that unstuck and popped it back on. The other side worries me a bit more. The other side seemed to be stuck pushed in, which means its frozen locked right? I'm not sure how im gonna unfreeze it. I piled in wd40 so i can get the hubs to lock and to get home. Im now gonna get some grease and repack em, but im just hoping i can get it unstuck, no wonder my gas mileage has been sucking.The other question is if i needed new o-rings for the hubs, i would go through warn im guessing right? I think everything else is okay, just super dirty. Do the hubs themselves come apart any more for cleaning purposes, its pretty gritty in there..
