k5 krawler 50
This last weekend my dad and i completely overhauled my blazer. I had set up this weekend to borrow a guys car lift so we could convert my stock k5 sitting on its little ol 33" ssr swampers to something pretty crazy. The whole weekned basically consisted of taking out the old 10 bolts, putting in the dana 60 and 14 bolt, and also hanging the new suspension. For the suspension, i'm running 8" lift 52" long tuff country springs, DIY4X rear shackle hangers and B-52's with a 7.25" shackle. For the rear I decided to go with a DIY4X shackle flip with johnny joints, 6" shackles, 4" lift 56" long tuff country springs, and a 1.5" zero rate. I also used Kerts 1" taller spring perches for the 14 bolt. Now, i know this sounds easy, but it was actually a lot of friggin work, even with the convience of a car lift. Like everyone else has said, frame rivits absolutely suck big time. That was the most time consuming part of the whole conversion, along with cutting of the cast spring perches off the 14ff. There are a couple of adjustments that i have to make to the front suspension as you will see, but for the most part, its finally a one ton. Here are some pics, i will get more pics tomorrow with the other tires up front.
before the swap w/ 33's
One side bolted up. I have the b-52's mounted in the most forward position, and the sping in the 2nd furthest hole to the front, but i think i am either going to move the springs to the furthest hole and see if that helps my shackle angle or if i should just leave it in the hole its in now, and put the rear hanger back in the stock location. I'm going to think about it a little more and try and figure it out.
spring hanging freely,
the 60 is in..
The rear suspension all bolted up and getting ready to weld on the new perches. I have the 56" springs flipped so the long side is in the front, then i used the zero rate to move it forward another 1.5in. so i actually ended up moving the rear back about 2.5 inches..
After we welded the perches, we bolted up two of or 40 in irok rollers to the rear, and two spare rollers to the front so we could get it on the trailer and get it home. Here are a couple shots of the truck sitting at home next to my brothers truck, which has a 4" lift and 35's...
the lift is not crocked, just one of the tires on the front is about 2 inches taller then the other one, and the ground kind of slopes where its parked...
Kert at DIY4X is probably the coolest dude to do business with. Not only are his products top notch, but he came throu for me in a way that you would not normally see from businesses. When i ordered the perches from him online, paypal did not send my message saying i wanted the taller ones, so he sent the regular hight ones. Well this was on tuesday, and i talked to him about it and he said that I could keep those ones and that he would send out the right ones via two day shipping all on him. That was the best customer service i've had to date. As you can see he also put in this johnny joint in his flip for me too.
Here are a couple pics of the horiffic shackle angle up front. Like i said earlier, i'm leaning towards leaving the front of the spring where it is and just moving the rear hanger to the stock location. But if anyone thinks i should try to just move the front spring and leave the hanger where it is let me know, and if your reasoning sells me i might try that first. I'm always down to hear other peoples opinions. Anyways to the pics..
oh and if any one is wondering, i used the stock bottom hole from the orginal bracket. Some have used the top, i just ended up using the bottom...
Well there is my weekend at a glance. I cant wait to see how this thing actually works when its driving... on 47's... lastly, this could not have been done with out the help of my dad... he was a rivit drilling animal, and he kept plugging away with me both days, so a big thanks goes out to him..
the 60 is in..
make sure to post more pics when the 47's arrive.
I want some sooooo bad but they look like they'd be brutal on parts.
