a little lower and the truck will fit in the garage.
I have plans to lower the suspension, move the front axle forward and remove the body lift. then it will fit with the 44's. It was not even close when it had a 3" body lift and a roll bar.
now I just have to get an I-beam to hold the garage roof up so that I can remove the center post. If I can fit it in the garage I can cut the trucks roof off and tube it out. right now the roof keeps the dash dry.
I have plans to lower the suspension, move the front axle forward and remove the body lift. then it will fit with the 44's. It was not even close when it had a 3" body lift and a roll bar.now I just have to get an I-beam to hold the garage roof up so that I can remove the center post. If I can fit it in the garage I can cut the trucks roof off and tube it out. right now the roof keeps the dash dry.
DEE DEE DEE
