jpdrake
my 98 k1500 the abs light has been on for a few weeks now and my code scanner dosent have a brake option? when the abs light comes on is it throwing a code? so i took it to a mechanic who said i needed a wheel cyl. and master cyl. so i replaced both wheel cyl and calipers and master cyl <after i bench bleed it> bleed the whole brake system and im still where i started. pedel goes to the floor wich turns on brake light while the abs light stays on constantly even after diconecting the batt and pulling the fuse.
what the hell should i do know i just wasted over $200 and still have the same problem
