Jeffs 90 k5 Floor repair
googlem
Registered Member
mn
Goin to be replacing the rear section of cab floor, rockers and complete tailgate section soon. I have been doing a ton of research and feel comfortable enough to start, But could use some pictures of the rear cab floor section from under the truck. I would like to see where the seat belts mount on side but from under the truck. If someone could post me a pic I would really appreciate it.
you can't see them from under the truck.. they are at the bottom of the b-pillar....
I mean where the lower seat belt strap bolt mounts to the lower side carpet. Not the actual seat belt mechanism mounted mid way up. On my truck that whole corner is rotted out and I would like to see how that rear corner sections looks from under the truck. I'll post a picture of my problem area's tomorrow.
When it ain't rusted you cannot see any of that anchor point from below. There is a reinforced rectangular washer/nut spot welded to the back that the anchor bolt goes through. This is all buried in the bottom of the 'B' pillar above the rocker assembly...making it not visible from below.
