I didn't realize the Johnny Joint was going to require a special tool to assemble it. I tried using vicegrip c-clamps, but that didn't work. You can buy a tool for $100.
So I made my own tool.
I used short pieces of 1.5" DOM, 2" flat strap, (2) 9/16" washers, and a 5.5" long 9/16" bolt (&nut).
Here are a couple of pics:
The 1.5" DOM was almost too bit though. It took a bit of persuasion to get the snap ring in. It would be better with something that had an OD of about 1.375".
Hopefully this will help someone else installing Johnny Joints in the future.
So I made my own tool.I used short pieces of 1.5" DOM, 2" flat strap, (2) 9/16" washers, and a 5.5" long 9/16" bolt (&nut).
I made my own bar because I have moved the axle back 4", so I knew I couldn't use an off the shelf bar. The overall length ended up at just under 4'.
