Well I'm thinking of selling my 1988 K-5 blazer.
more pics here: click
It's got 350 TBI/700R4/NP208/10bolts front&rear, and 33" tires. I put an XJ steering shaft on it, new fuel filter, pcv valve, pass side brake caliper, fixed the messed up steering column (tilt). It has 110k miles on it.
Now the bad It needs a fuel line repaired (return line is cracked) and the rear brake line that runs inside the frame is cracked so that needs to be repaired.
Also the pass side front fender has a big dent in it, a new aftermarket one is included. I also have a new headlight bucket and grill, both aftermarket. And I just picked up a new billet grill that would be included as well.
The previous owner started to restore it. The frame is rusty but the body is very clean. The rockers are new, there is some rust by the rear wheelwells. I would probably want $2000 but that is negotiable of course.
I have lots of extra things that could be included for extra $. I have 90% of a 4" lift (Tuff Country) I have two more tops and I have a 3/4 ton front 10-bolt if you were thinking of doing a 3/4 ton axle swap.
Thanks,
-Ryan
Thanks,
-Ryan
