Jump seat for Blazer
I have an older one - maybe mid 2000's. I was able to modify the base a little to avoid putting more holes in the floor. One corner shares a bolt hole with drivers seat, one uses the original hole for the flip-forward seat cable. The FR corner is folded up to simply bolt to the PS seat base. This works well for me because I sometimes remove the center seat to run a refrigerator. Also, the factory console would bolt in if I ever wanted to.
If you plan to bolt it in and leave it, having nuts under the floor might be acceptable, but you always have the option of welding the nuts in place so it's simple to bolt them entirely from the top.
Appreciate it guys. And I like the earlier version of the jumper better too, but it was such a good deal (gone now).
Cool to see all of this interior pics muddybuddy!
I also run an early 2000s one. Same thing as said above for bolting it in. Now days we don't roll 6 deep as much so I wouldn't mind swapping to a newer flip down style with cupholders. Mine is a fixed work truck style.
I have the flip-up that's a console or seat. I recovered the bottom cushion years ago with upholstery from another Blazer seat, but the top cushion is still gray vinyl. I guess I never figured out how to get the plastic insert off so the vinyl can be removed.
