Junction block location
Wes Harden
1 ton status
Staff member
Moderator
Solutions
Lake Havasu City AZ
Anybody know where the rear lamp junction block might be located on my 2001 Suburban 2500 2wd ? this the beasty i am looking for,
I have looked around the frame rails at the rear, nothing so far.
This truck has a tank above the spare and one mid frame driver side.
As a former user of Alldata, my hopes were not high, and I was not let down.
Nothing on that cross member. Loom is on body above cross member, and no junction block there either
I should lower the spare and look I guess. I am not totally sold on this truck having one. Do all gmt800 have this junction block.
On a friends 2004 1/2t burb it was behind the passenger side wheel well, mounted to the floor of the body if I remember right. It a was full of road grime. It’s clipped in a bracket(that’s why the one end is miter cut) and you just pry it loose with a screwdriver. We changed it because the brake lights were stuck on, ended up being an issue up at the pedal.
I thought it was in the passenger side floor at the very back, kind of passing into the rear heat and A/C box.
There almost has to be one since the harness would be on the frame rail and the body is dropped on later.
After much more Google fu, I am convinced the 2001 suburban did not get a junction block. Suburbans seem to get them in 2002. I still haven't found my short. Haven't looked much more.
The license plate frame back up camera has 6 led lights, when I reverse these lights light. Towing the boat last weekend I needed to use the mechanical surge brake lock out. Seems my trailer wiring isn't powering the reverse circuit, I had thought the camera lights were hooked to the same circuit as the trailer plug.
Move inspection of trailer wiring is next step for me.
