I don't know much about the crush sleeve eliminators...it makes me question the purpose of a crush sleeve and how the eliminator substitutes in there. I understand preload, but what else does a crush sleeve do and why ever use one if a spacer can work?
Axles (any make/model) are ~50/50 whether they use crush sleeves or shims.
Shims are better every time. The ONLY reason that crush sleeves exist is because they can be installed in one shot, with shims it's likely it will have to be assembled, measured, then changed. Repeat. Crush sleeves are simply exist to cut install time.
