Not sure if it helps, but I normally drill a small hole at the end of a crack then weld it up
This^. Stop drilling as it is called gives the crack a place "to go". It is standard practice in the aviation industry. I always drilled slightly ahead of the crack because the metal is usually cracked already but it's to small to see yet. I was not aware more folks don't know this. Always a good idea...
