So I pulled apart a 14BFF to put in a Detroit and one of the carrier bearings is smoked. I'm putting new bearings on both sides. I did not remove the pinion housing from the case.
I assume I need to reset backlash since the bearings will have been replaced. That should be all, right (i.e.: pinion depth shouldn't need messing with)?
I screwed up and failed to measure the backlash before I pulled the carrier, so should I just set it at .008" and look for a decent paint pattern?
