I crank it up and leave it there... haven't broke anything yet and 33 gallon tank typically does fine; however, I believe if you set to what each tool recommends, it wont waste excess air...
Our old compressors cutoff switch started self adjusting before it finally bit the dust. I found out my 3/8 impact would break lug studs with ease at 190psi.
I keep my service truck set at 125, home is around 120.
I adjust mine all the time depending on the tool. I just use the tool recommendation. Until something is being a **** **** **** ****. Then I crank that bitch up
