durantk5NC
Newbie
I just got done installing my crossover steering kit from ORD and I am having a couple of issues with it. I feel like my 88 k5 is pushing the front end hard when making turns and there seems to be a little bit of bump steer. Also, I dont think that my steering pump is bled all of the way. what is the proper technique for doing so? I turned lock to lock many times with the blazer running and added more fluid but i still have that whining and not full steering power. thanks for the advice.
I have also considered that I have my drag link ends too tight which may be contributing to my problem. This is a great set up tho once i get it dialed in.
I had to weld on some big ole washers on my front spring mount cause the bolt holes were rounded out so bad from it
