wasted wages
1 ton status
If you were building a buggy or truggy for off road only.....whats the down side of building your own chain driven transfer system out of pillow block bearings, keyed shafts, multi row toothed gears and chain ?
I know you wouldn't have the advantage of netural or taking it out of 4 wheel drive....but think about the unlimited amount of gearing and crawl ratios that could be obtained....
simple in design...parts easily available...heck...35 spline D60 shafts could be used and cut down...
build it like a divorced case...
build a crossmember cradle....mount the bearings,,,cut down some shafts...
get some gears and chain....your done !
I think I have seen something like this used on mud racers....but with only a single ratio...1.1
I'm thinking a primary chain from the trans to the output shafts, would allow the reduction to happen with different sized gears....
OK shoot holes in my theory !!
