I need some patch metal for my 1009, anybody cutting up a parts truck?
Looking for the cab corners behind the door where it ties into the rocker and upper quarters around the wheel well
Well I looked at it yesterday and it's pretty clean, just scratched paint.I circled the area i need in this pic. I need both sides, (driver and passenger)
I am going to take some measurements and see what I can fit in a large flat rate box and see if that is good enough for you, then we know what the shipping will be, if it end up being too small then I will cut a foot in each direction I am sure that will be enough.Sweet! Thanks. Id say the more metal the better. Maybe just take a long blade and rip through both the inner and outer skin. I need as much of that corner door jamb as possible, mine is rotted almost to the floor. If you wouldn't mind just cutting out the whole corner chunk it would be much appreciated. Let me know what you want for both driver and pass sides shipped to 60609. Thanks again
Matt
