k10 electric fan help
we have a full write up on ford windstar fan swap in and how to wire it.
little searching will pull it up.
there almost a bolt in job about as close as you can get on the cheep.
Whatever fans you get, I don't think I'd go with dual 10" units, measure the width of the radiator and try to go with a couple that will fill the most space.
The '05 Avalanche here is running dual electrics, haven't measured them, but they span the whole width of the radiator and definately keep things cool, even in Phoenix Arizona summer heat.
I DON'T think it's factory either, I tried for a short bit to find replacements, because I wanted to run something similar on my Burb, couldn't find anything on them.
Just went out and took pics of the fan setup, it does appear to be a factory deal, nice setup, took pics, but need to take new ones, they didn't work out for some reason.
gm did start using factory electric fans in trucks and suv's full size few years ago. the h20 pump still has the threads on it for engine drivin fan also .
