ciffer
the transmission on the k10 finally died. it lost everything but first and reverse.
i have a spare late-87 700r4 sitting around with a shift kit and a heavy duty servo installed. to the best of my knowledge, the transmission works great, assuming i did everything correctly with the shift kit.
i am going to install the spare into the 85 k10 and pray that it works. i have not changed a transmission before but i am no stranger to the greasy side of trucks.
here is my understanding on the step by step.
remove driveshafts and disconnect shift linkages, tv cable, speedo cable etc.
unbolt transfer case from transmission
remove cross member and remove transfer case
unbolt transmission and remove transmission from engine.
here are my questions.
1. what do i need to do with the torque converter?
2. did i miss anything on the step-by-step?
3. is there anything i need, or need to do to prepare, parts, tools, etc.
