cochino12
I recently bought an 85 1/2 ton that the PO swapped 3/4 ton axles and 6" leafs w/4" steering arm. The steering is a little sloppy and sometimes after the truck starts to turn just a bit on very slight turns the wheel will jerk pretty good. It used to be mainly just at low speeds but now its doing it more at higher speeds too. Other than checking the frame steering box area for cracks what else should I look for? and how do I know if tie rod ends, ball jonts etc... are bad. Thanks, in advance
Adam
Adam
