Been going through this 84 k30. Threw new tires on it the other day so I could actually drive it safely. New 3 port Delphi mechanical pump. Had a Napa one on there but it lasted about 5 min before it ruptured. New wix filter in the carb with the check valve. Has all the smog pump stuff still hooked up but I do need to replace some vacuum lines for sure.
Issue is when I give it decent throttle it cuts out or is having some kind of issue at 35-40 mph. Right when it’s about to shift 2-3. It will then “catch” itself and continue normally. Driving all the way to 65+mph. Any ideas? Consistently does it at 35-40.
