dremu said:It's a CUCV body/drivetrain (can't remember about the frame) dropped onto a pair of crazy big ZF axles, made for low-speed high torque, with like 6.72:1 gears or somesuch. As said, no springs
First pic I've seen of the engine compartment; that brake master is gnarly, and the cover/drip-pan for it is wild!
-- A
Yeah, now that you say it that sounds right.1979jimmy350 said:i belive that it is lower than 6.72 i think it may have been as low as 20:1
dremu said:First pic I've seen of the engine compartment; that brake master is gnarly, and the cover/drip-pan for it is wild!
-- A
littlejimmythatcould said:I believe they still have 1 ton stuff under them. Jacking it up and doing the wheel spin counting test would be the only real way to tell. Plus the Dodge one that I drove had the cummins in it, so it was hard to tell if it was the motor or the gearing. But it 4 low it didn't like to go more than 10 mph. I would think 44's would be no problem, but then again, they might not all be the same across the board it might depend on how they were ordered for the military.
