trevmountain
So I got my ORD 1 inch body lift installed thanks to the tips from you guys and I also got another inch in suspension with an ez inch up front and a taller block in the rear while using ORD's ubolt flip kit.
My question is how are my angles looking? I am getting a bit of vibration. My next move is to install my new Gear Vendor so I am going to lose some drive shaft length there as well so the angles are going to be even steeper. How do I shim things accordingly and at what point am I out of cheap options before resorting to drive shaft modifications ect..
Thanks in advance
Thanks in advance
