Found K30 stock rear shackle hanger brackets
sweetk30
Back to play nice .
in the back of your brain
looking for a set of stock rear shackle hanger brackets and support brackets for a k30 .
let me know what you have thanks .
possible trade for home brew flip kit i have . its made from stock 2wd front hangers and bolt on with 4 side bolts like stock and 2 lower support bolts like stock . pics can be sent if need be .
Damn I wonder if I tossed mine out when I did a shackle flip on the M1008.
i might have a set here but my shop is so mixed up and messed up now i got no clue were they would be .
I know I have the stock rear hanger off of my crew cab, I think the support bracket is still on the frame.
I will check.
well today digging out the 9ft snow plow on my storage trailer i just happen to find a set of hangers and brackets i needed .
so if your making a specific pull of the parts for me @imiceman44 then you can stop for now . i think i am good for this project at this time .
No problem I am pulling them to get the shackle flip put on.
i might still take them if the deal is right . . . never know what is going on with my build plans for 2 other k30's .
@imiceman44 If you still have those hangers I maybe interested. I'm building a trailer and can't find the ones I torched off my original frame. I'd like to get the rear hangers as well if you have them.
It's a half frame, but it's just going to be a utility trailer so I don't think it has to be perfect......It can be made to fit if the deal is right. :D
If I needed to I could probably bend up some scrap metal and make em work, but these may look better.
I have a frame that is a 1/2 ton with hangers I will see in what shape they are in.
c/k 30 hangers are 1" narrower per side . so it would be build out 1" per side . i would go for his 1/2 ton hangers to make your life fast and easy .
