B
Bohemian
Guest
82 Chevy K5 Blazer.
I'm in the process of trying to r&r my 38 year old body mounts.
The truck has been in the southern nevada desert it's entire life so there's no rust.
Before I started I read everything I could google on doing this job.
I presoaked everything with PB Blaster for weeks before I started.
The concensus seemed to be that the rear most 4 are typically the most problematic.
So I started at the back & worked towards the front, which served me well.
Everything I read said to loosen but not remove the body bolts, till you replace the mounts 1 at a time, 1 side of truck at a time. I suspect to help keep body movement to a minimum once they're all loose.
I was able to get the nuts off the 4 rear carriage bolts, and the two front most mounts and loosen the 4 center most bolts enough to be able to remove them with my fingers when it came to actually replacing the mounts.
After verifying there was nothing keeping the body from being lifted up a few inches to r&r the mounts; I jacked up one side of truck and started replacing mounts back to front.
All was well until I got to the front mount & while the nut was off the bolt; the special dished cup & spacer with a eliptical metal boss that holds the mount appears to be seized onto the bolt. If you turn the bolt the whole thing turns as one assembly; and I can't separate it from the bolt to remove it.
I've beat on the bolt from underneath the truck with a big drift & a bfh, I've tried to beat a chisel between the radiator core support & mount as a wedge, I've tried several different prybars, I've PB Blaster'd it and repeated the bfh & drift treatment for several days. It just seems rust welded in there, even though the threads that are exposed are clean & rust free and the nut came off pretty easy that pos ain't budging. I can't get a sawzall blade in-between the radiator core support and body mount base to move on either.
So I'm stuck at the moment if anybody has any suggestions, I'd appreciate it.
thanks in advance.
thanks in advance.
