B
Bohemian
Guest
82 K5 Blazer, factory axles, springs and shocks at the moment.
So in the process of gas tank r&r I noticed the drivers side rear upper shock mount was fubar & had been previously repaired and badly done at that, fugly welds that only partially penetrated the frame in a few spots and barely if at all penetrated the mount, looks like someone stick welded a mess...
Thankfully no evidence of frame cracks and or frame repairs in that area.
So I air hammered the heads of the rivets of the mount, then had to use a sawzall, cutoff wheel, die grinder, 4-1/2" grinder, flap discs, and grinding wheels to get the poorly welded, (big pile of weld doing nothing) to the frame shock mount off... not fun.
My current problem is the rivets with the heads off on the top side won't budge and there's not enough wailing room to use a small sledge hammer or any other hammer for that matter to knock them out.
I don't have room for any air hammer attachments either, at least the ones I have or any I currently know of; there's just not enough room between the frame rail and bottom of bed, and the angle is to flat to get something on it from the side.
So if anyone has any ideas how to get those rivets the rest of the way out without taking the body off I'd appreciate it.
Also, on a related side note has anyone ever run across any of these mounts that only had 4 of the 6 rivets holding the mount down from the factory?
That was the case with mine, I checked real close and it never had the rear most two rivets or those holes drilled in the frame from the factory; no welded up holes either, they just were never there from the get go and that's one of the places the mount broke.
thanks in advance
thanks in advance
And I've been jonesing for some Bilsteins lol.
