86gmcjimmy32
Registered Member
Hey guys would like some ideas on new leaf springs for my 86 k5. I’m finishing off an ls swap in it now and am planning on grabbing myself some cucv 1 ton axles. The blazer now I believe has a 6” lift and rides like hell. Probably rough country springs. I’ve done some research and am thinking of going with tuff country EZ ride. Would like some opinions from those of you with this lift. Was also wondering if I should go with the longer 52” springs in the rear? And if so how would I do that. I hear a shackle flip is what I’m after to make that work, but was also told that nets an additional 4” of lift. Is that so with 52” springs? or is that only with the original 48” springs? I want something to ride well on the road and be able to handle some good wheeling here and there. Would like to run tires in the 37”-40” range but have not yet decided. Will the 6” get me there to clear these? It seems like I could at least fit 38s with the lift I have on it now but I hate the ride it has. I’m also open to other spring ideas? It already has a tcase drop kit and needs new driveshafts so that’s not a worry. Let me know what you guys think, and be willing to share what you’ve got on your setup.
