K5 Blazer Leaking Clutch Fluid
Charleshugh
North Carolina
Hey guys, I’ve been having trouble with my clutch fluid leaking recently. From my research I know I should replace the master cylinder and the slave cylinder. Are there benefits to some cylinders over others? Do you guys have any advice regarding what to buy or what has worked well?
Thank you,
Hugh Kennedy
Thank you,
Hugh Kennedy
I think they work pretty much all the same. Its not adjustable, you just need the right parts. I have LUK parts for the clutch in my K5. My Suburban is still stock and my Crew Cab has AC Delco replacement parts. All 3 clutches feel about the same in effort and pedal travel.
