K5 Center console DIY switches, etc…
Chris Ziemer
Daily Driver
Galt CA
Hi all, looking for ideas for DIY consoles to house the switches for my 82 K5. Mostly lights, but would like to maybe house a CB also. Right now, I have a little bungee cord holding a gaggle of switches against my kick panel!
I have an automatic w/the 4wd shifter on the floor, so not immediately sure how that would all fit.
Any pics/ideas you have would be appreciated. Where do you mount your switches?
couple of threads with ideas and solutions peps have used
Thank you!
Here's mine. Grab a couple pieces of 060 aluminum, some rivets and bend it up. If you want it cut out I could dig up the files. (I think)
Wow, that’s a great idea. Super nice job getting that together.
That’s a great idea too. I’m a little partial to my plastic behemoth, but a change may be in order.
You know what, I was looking at the Amazon unit Kain had sent and I saw a few different styles on there. I thought I was partial to the original unit, but there are some huge benefits to them. Looking at the one below. I’ll be spoiled if I can set my coffee cup somewhere besides on my left leg haha.
I’m not sure it solves my switch problem, but its a nice upgrade all the same.
Rampage Locking Center Console | Grey Denim | 31511 | Fits 1976 - 1995 Jeep CJ & Wrangler YJ https://a.co/d/84iNyWF
I didn’t even know I made a center console. :doah:
You'll want to make sure the width is what you're looking for.
Doesn't answer the radio question, but I noticed the ashtray assembly is screwed into the dash. Would be cool if someone made a panel that replaced that whole assembly , designed for switches and flush-mount USB/cigarette lighter plugs.
Edit: not talking anything complex...either a metal panel that matches the contour of the dash, or a squared off piece. Either way, something that attaches using the same screw holes as the ashtray assembly.
Also be really nice if it had a "slot" that held a cell phone.
Now you got me thinking about what to do with that ash tray... maybe i leave the door alone and modify the actual ash tray for a couple of switches, or storage or something... still be able to flip it up and hide away inside the color matched factory cover...
I have a CB bolted to the front of my factory console... its in a good spot, but all I can fit with the gear shifter swinging around that area.... and the left side cup holder is useless, because if I put something in it, it is in the way of my wrist while shifting in and out of 2nd and 4th... (or 1st/3rd depending on if you count that granny gear as a regular forward gear or not)
I really like the ashtray idea too. And I may bolt my CB to the front of my console too. Automatic, so plenty of room. I had found another thread on consoles and copied this picture. I think I’m going to use the same concept only move the cupholders towards the console lid as far as I can, which will leave me plenty of room for toggle switches.
I dig the cyborg GM console! mine is all cracked... and recently found out my "spare" has just as many cracks :frown
had thought i was gonna need to do the Chinamazon jeep console at some point, but maybe i just need to reinforce mine with some aluminum and add stuff to it???
would match the emergency cut off on my seat frame!
Haha, cyborg GM. Has a ring to it. Mine was cracked some as well. Some resin epoxy and paint was all she needed.
I feel like I’m knee-deep in projects right now, so it’s probably going to wait a few weeks. I just bought a roll bar for my 82 out of Nebraska from off-road LTD. Putting that in now.
This individual makes an ashtray replacement "panel". https://www.etsy.com/listing/688027846/73-87-square-body-chevy-gmc-ashtray
I've asked if one could be made that replaced the whole assembly but haven't heard back.
That’s a good find. I did see that panel in my searching, but clearly didn’t catch onto the fact it was for the ashtray.
I think it’s a great start, but a contoured fixed panel would be preferable. It’s got me thinking. Nicely remove the ashtray/lighter portion, leave the pivot point and maybe a magnetic closure - if necessary? 5 switches and a 12v in the ashtray door?
Man, these are exactly the problems I love, but don’t need!
83 Blazer, you’re ahead of your time!
