getmillican
Newbie
Hello everyone. I don't normally post new threads since I can almost always find the answer in another thread, but this issue has be stumped. I'm replacing the inner and outer weatherstripping for the hard-shell on my 1984 K5 Jimmy. On my model (and most others I've seen), the rear interior light harness passes through a hole in the upper rear carb, routes under the outer weatherstripping down the driver side, and around the interior side of the B-pillar before connecting through a small window on the driver side hard-shell. Has anyone successfully re-routed this wire inside of the B-pillar instead of outside under the weatherstripping? I appreciate any thoughts, comments, cautions or suggestions.
