I have a wierd one. 87 Jimmy. I have made a pig tail to run the Jimmy lights off of the semi while in transports, The Jimmy hangs 2 feet past the tail lights on the semi. The semi lights are down low below the Jimmy tires. I have many instances where I people have not seen my blinkers running. Or they are just jerks.
I ran 4 wires from the semi 7 spade plug and yes, they are wired correctly. Test light on the ground and the blinkers work correctly as well as the tail light feed.
Installed a 4 wire weather pack into the harness at the left rear frame rail. Wires there work correctly from the Jimmy. Wired the same as the feed from the semi. Ran a separate ground from the semi feed to the Jimmy body. I have double checked that the plugs are all the same. Multiple times.
Tail lights work fine. With either blinker being ran on the semi, all of the blinkers work on the Jimmy.??????? Took everything apart multiple times checking connections.
Disconnected the ground to the Jimmy battery.
Pulled the hazard fuse and flasher.
Nothing changes it.
Is here a connection somewhere in the Jimmy that I am missing. Only thing I can come up with is the hazard control in the column.
I am stumped. And electrical rarely does that.
Nothing changes it.
