Definitely a better use of your time than investing effort in that TBI 350.
Put a Vortec fuel pump in the TBI gas tank, run some FI fuel lines, work through a few wiring harness issues, maybe a bigger radiator, and some exhaust work and you should be well on your way. Obviously that's simplifying things, but the BBC will bolt right in and isn't too hard to adapt.
I am in the process of doing a 350 TBI swap for a 454 Vortec. But the project I'm working on is going to take some time and money. I have a donor vehicle that I got the harness and 4l80e from. I had a 454 Vortec engine, before I got the donor, and had it rebuilt because one cylinder had a verticle scratch that I wasn't sure of. The 454 was bored out .030 and an RV cam put in. I am slowly putting the top end together right now. It consists of new injectors, cleaning and painting the upper intake and all brackets.
I'll replace the ignition coil and sensors so I know they won't cause any start up problems. That will give me spares for the trails.
I am rebuilding the 4l80e and that will take a little while because as stated before, I'm not in any hurry. And because the tranny is longer than the 700r4 that is in it now, it will need the rear drive shaft shortened and the front drive shaft lengthened. That's a Tom Woods project.
I'm putting on headers and will need to build the exhaust since the kit that is on there now is getting old.
I had the harness, from the donor truck, worked on by
@Team208Motorsports. Along with them tuning the PCM. It looks like it is half of what I sent them. They really know their stuff.
You would have to decide on what time and money you have/want to spend on the project. If you're wanting it done fairly quick, then do the LS swap. There is nothing wrong with that. And you get a really good running rig. Plus it seems to be the norm now a days. But then again, I'm not norm. I'm going for displacement and torque with some gain in HP. I can't wait to get this thing up and running but I know that it's going to take some time. I will pull the front end off the blazer to make removing and installing the set up easier. Plus I need to modify the transmission crossmember to go with the tall lift. And installing the ORD engine HD crossmember and motor mounts. While I'm at it, I will clean up some under hood and dash wiring including painting the engine compartment.
While all this is going on I can still drive my Blazer. I have plenty to do and I really don't want it down and not running when there is a slight chance of snow coming in the future. I don't plan on doing the swap until after the new year. With all my aches and pains I can't get in any hurry.
As far as the 454 Vortec system and wiring sucks. Nope. Can't agree with that. The wiring isn't any more complex than TBI. Different? Yes. But not difficult to work with. The system itself? Seems they can both have pros and cons. I just haven't found any cons with the 454 Vortec. Yet. Not saying I won't but until the swap is complete I have none.
When all is said and done, it will be one bad a$$ 87 Blazer. And I can say I built it the way I wanted it. That was my choice.
