Ripped the carpet and backing out of the front of my "new to me" 91 K5. Floor isn't too bad and I want to keep it that way.
My thinking is to POR the entire floor/rear compartment. Then install one of the Vinal floor kits from LMC. My questions is that front/rear floor is NOT cheap. Is it worth it? Wondering if I can source it somewhere else or if it's even any good.
Thoughts?
Thoughts?
might be why it sux'd so bad. Anyways, got tired of looking at it and ended up Line Xing my whole interior. Looks better and dont have to worry bout much. Just have to make sure if you use ANY coatings, you prep, prep , prep and prep some more, There cant be an ounce of rust under the coating or it will eat thru your floor to the underside, trust me on that.
