Hey, during the discussion on fuel systems for the '74 K5 we have figured out there is a big difference that happens somewhere after '74; the GM engineers introduced the fuel return line.
So the number of people over on the '73+ side that can help me is not many. I think the thread should be here in the pre-73 world.
The short version: My fuel evaporates from my quadrajet in two days (I calc'ed the evap. rate and it is possible). My fuel is over 100 deg F in the fuel bowl and that causes the ethanol mix to evaporate - and some suspected back-flow down the fuel line does not help. The fuel bowl plugs seem to be leak free - no black smoke on startup, easy start after sitting short time. Should I insulate my fuel lines and put a wood spacer under the carb so at least the fuel in the bowl is closer to the 60 deg F in-tank temperature? Add a fuel return line? Add an electric pump to top-up the fuel bowl on startup? Live with it? Put my Holley back on? Find a source of q-jet design spec. lower voc '60s era fuel? Switch to fuel injection? Buy a prius?
Ideas --> http://coloradok5.com/forums/showthread.php?t=317338
